ECU Reset & Code definitions on '94Q45 Standard, non-California
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
I have some TSB's on my PC, but don't know which one describes the ECU Codes, or how to check or reset them.
Can someone either tell me which TSB to look at, or give me a quick run-down of the procedure?
Thanks!
Rex
Car: None
Don't have the TSB's and sounds like you're having a rough day :(
Does Wes' post mid way down help? http://www.nissaninfiniticlub....41287
Hope it does. Or this?http://www.troublecodes.net/infinity/
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
With Rex's troublecodes link, stop at code 55 (start with 11 I think)
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
Thanks, Guys, the day is going muc hbetter, today.
I will try again, next Saturday. I need to replace the Tension Rods, Sway Bar Bushings, and the passenger Window Regulator.
The driver's side valve cover gasket will have to wait until Thanksgiving weekend, I think. I need the plenum gasket, and the hose between the plenum and the brake booster (it is hard as a rock).
If any of you know of any other hoses, or gaskets I might need, just chime in.
Q45tech
Usually half of the $1,000 worth of hoses [retail price of all the vacuum, fuel, pcv, brake, heater, coolant,etc hoses] is enough.
It's always the ones you don't have that break on disassembly.
