ECU RESET AFTER INTAKE MOD ON G35S
gama
Car: 2007 G35 Sedan S
does anyone know for sure if we should reset the computer after mod on intake? if yes how?
G_whizz
Car: 2010 G37 Coupe Sport
I never did it (or had to) do it on mine after I installed my Mods.
Try here http://www.nicoclub.com/articles.php?id=182299
Hope that helps!
cd001111
disconnect POSITIVE side of battery, wait 8 hours
gama
THATS WHAT I THOUGHT TOO!!! couple of hours unplugged
joe603
Car: 2014 Durango R/T
cd001111 wrote:disconnect POSITIVE side of battery, wait 8 hours
Never, never only disconnect the positive of a battery for a car without first disconnecting the negative. You WILL get a spark show or worse!
I've heard that you can also disconnect the negative, then pump the brakes a few times to discharge the ECU caps...it's the same as doing the ECU reset via the gas pedal.
Gimli G35
Car: 1996 Lexus ES300
i prefer the old fashion CEL flash gas pedal way , scared of frying myself ... again .. ahh no smiley with a shocking thing except this one
KulG35
Car: 2007 G35S Sedan 6MT
I was told you should to let your ECU "relearn" or adapt to the new intake since in change air/fuel ratio slightly. I talked to a deal and they wanted 200 to reset ECU....
ArizonaG35
Car: 2007 Infiniti G35 Journey Sedan/Premium Pkg. Platinum Graphite
That dealer was trying to rip you off... I'll reset it for you for no more than $150.00... any takers?
gama
.. i was told you dont have too! it will adjust after couple of miles driving!!!!! so if the dealer tells you to do it.. i beleive they want your pocket
cd001111
After you re done removing codes, keep an eye out because chances are it's going to do it again.
