ECU Removal
Wrd_32
Car: 1995 240sx
I'm currently swapping my KA for a SR and I need to pull the ECU wiring to send of to the specialist to have it rewired and I was wondering what all has to happen for me to remove the wiring.
Wrd_32
Car: 1995 240sx
SOrry, it's a 1995 240sx and its a OBD1
modulation
Are you sure it's ODBI? I thought that they transitioned over to ODBII during 1994...
Removing the wiring is going to be a *****. Not really hard, just time consuming.You are going to have to remove your dash, alot of panels by doors etc.
Do you have a FSM (factory service manual?)If not search google or these forums and find one.Look in the electrical section at harness locaitons, and find the ECU harness and find out where all it branches off to. You'll have to get to all those locations and unplug the harness from the sub-harnesses.
Good luck.
