Movingviolation240 »
https://forums.nicoclub.com/movingviolation240-u104.html
Wed Jul 23, 2003 6:12 pm
the problem is the stock system isn't designed to run a high HP motor, it's just limited. Like a stock T25, you can bore it all you want, make it into a big 28, but eventually you have to give it up and go bigger.
Standalone is going to start off at like 1,000 and go up from there, then another 500 to have it tunned. And install if your not up to that (another 3 or 4 hundred I'd guess)
