ECU relay?
WhiteKnight
Car: Nissan 240SX
What is it and where is it?
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
WhiteKnight wrote:What is it and where is it?
what are you trying to do?
ca18drifta
Car: 240sx
I think you talking about the dropping resivor. if thats how you say it lol
ca18detgabby
03 Infiniti G35
ca18drifta wrote:I think you talking about the dropping resivor. if thats how you say it lol
its a resistor..... It isnt anything like a relay.....
ca18drifta
Car: 240sx
whoops lol
WhiteKnight
Car: Nissan 240SX
Some thread said I should check the ECU relay. Where is the resistor?
ca18detgabby
03 Infiniti G35
either post a link or explain what the issue is. there are tons of different connections and all do different things. if you dont know what you are looking for and i point you in the wrong direction you are even farther up shi t creek.
might as well do it right the first time.
there is alot of different resistors...... he is speaking of the DROPPING RESISTOR which is a box(silver usually in color) that is separate from the ECU and that reduces the IMPEDENCE so that the injectors will fire properly.
WhiteKnight
Car: Nissan 240SX
I have an idle problem on decel when braking.......someone said check the ECU [resistor]
ca18detgabby
03 Infiniti G35
idle problem on breaking still doesnt tell much. relays are what tell things to go on and off..... such as fan relays, igintion relays, and AC relays. when it gets a signal to trigger it flips and sends current. till it gets the signal it does not send the current.
a resistor affects the amount of current passing in a circuit.
can you tell me what issues it is exactly? is it jumping up and down? is it attempting ot stall? what does it do at idle?
I would start with something very important and simple and suggest cleaning the maf....
WhiteKnight
Car: Nissan 240SX
I overoiled the K&N so now I have to clean the IAT in the MAF. But the idle is from the IAA so next week I'll get into all of this. The idle drops to 500rpm when I brake. There's other threads talking about this. Someone brought up the ECU [relay] so I was curious.
boost_boy
WhiteKnight wrote:I overoiled the K&N so now I have to clean the IAT in the MAF. But the idle is from the IAA so next week I'll get into all of this. The idle drops to 500rpm when I brake. There's other threads talking about this. Someone brought up the ECU [relay] so I was curious.
ECU relay or whatever their stressing has nothing to do with your idle . Start looking at your idle control section as well as vacuum hoses.
Dee
Bwana
Car: Denali
Sounds like it could easily be a vacuum leak to me.
ca18detgabby
03 Infiniti G35
Bwana wrote:Sounds like it could easily be a vacuum leak to me.
agreed
