When I went to pull my codes the red L.E.D light was already on. If I was reading right from this web site
http://www.240sx.org/faq/artic...h.htm
then this means that The ECU's CPU or the Crank Angle sensor is malfunctioning.
Then I turned the knob and it was blinking in a certain order not really to sure on how to to pull the codes or I would tell you the codes. My car isn't starting so would the crank angle sensor cause this?
