ECU question
Is a 94 Q45 ECU compatible with a late-production 95 Q?
Both are federal, non-TCS, non-HICAS cars.
Q451990
Do you know if they're the same part number? The TSB I have only goes through the 94 model year.
Heath
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Hitman, might as well try it and if it doesnt work out you can pass it on to the next person.... I think it will be fine, even though the part numbers are different!
EDIT: If I had to put my 2 cents worth, Id say it would work fine....
Well, I just don't wanna drop the cash on it if it won't work...
elwesso
2007 BMW M Coupe
Still havent heard back from Glenn... :(
Q451990
Any chance Joe could tell you if the part numbers are the same, or you could compare the numbers on yours with the one you'd be buying? If they're the same you'd know for sure - otherwise you'd be taking a chance...
Heath
Well, I now have a 94 Q ECU.... Hope it works. :)
If it will work, I will install it temporarily while my ECu is being sent to JWT for some much-needed tweaking.
rsiwicki
Car: 95 Q45T
So how did the ECU work? did you put the 94 into the 95?
Not yet -
Too busy installing the 4.08 rearend, new rotors, SS lines, ATE Blue fluid and some other assorted tweaks... :)
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
If it works, and when you get your modified one back from JWT, I'll take the spare off your hands, to send to JWT, for modification.
I just happen to have a 1994 Non-TCS, Non-HICAS, and Non-California Q45, that needs the JWT modified ECU.
