ecu question?
turbodrig
i have a 93 nissan hardbody im swappin my ka24e for a det ka i was wondering if the ecu from a 240 s14 would work in my truck?
dvdswan
get the wiring harness as well from the 240.
seang
Car: Ford Fiesta ST
I'm thinking the S14 ECU might not only work, but also be required for the DE motor swap.
turbodrig
well i know the de has the same plughs all but one and i was curios if i could use myu wiring harness and plug the s14 or s13 ecu into that?
seang
Car: Ford Fiesta ST
I'm not sure myself, I would hate to tell you to go ahead and try it then have something burn out. The truck has Hitachi and the 240sx has Jecs ECU's, and I believe the truck is 8-bit where the 240sx DE is 16-bit.
I read a few days ago in the KA forum where an owner tried a SOHC ECU on a DOHC motor, and it would idle but not run above that, so I don't know.
