ECU question
PhatQ45
Car: 95 Q45
My 95 Q45 ECU is dead. My friend got spare 93 ECU with TCS. I plug in engine start normal but I check the code manually there is one.. code 46 Secondary Throtle position sensor. Can I use this ECU instead spend few hundreds $$$ get another one. I dont want my engine stall on the road.
Q45tech
Depends on what "on the road means to you"I have spares of every electronic module in my Q45, When I drive beyond 100 miles away from inventorym I carry my emergency module and parts kit in trunk so I a not forced to wait for FEDEX or flatbed the car back home.
Obviously one cannot carry an engine or transmission so there is always some risk but that is managable.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
I guess one question is why is your ECU dead? These don't fail in normal operation.
Sounds like you got one out of a TCS equipped car. You can use the earlier 8 bit one, but it will not control your 2 speed auxiliary cooling fan correctly.
PhatQ45
Car: 95 Q45
I dont think it has anything to do with aux cooling fan. I check the 90-95 ECU diagram, TCS equipped Q45 has additional throttle motor sentor connect to trottle control, the ECU reply on this sensor sent nessary info to TCM (throttle control module). I test drive the car this morning she runs good and everything seem fine.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
The later 1994+ had a two speed auxiliary cooling fan. The earlier ones only had a one speed fan.
PhatQ45
Car: 95 Q45
you mean the fan in front of radiator?
PhatQ45
Car: 95 Q45
As long as cooling fan in front of radiator is running when it suppose to I guess it all good I keep it. THis ECU run better than my original ECU.
qsiguy
Car: 1994 Infiniti Q45 Turbo
The cooling fan issue is irrelevant to this post. It is a minor issue with using an older ecu with a newer Q. The trouble code is as Brian stated, you have an ecu for a TCS car and you don't have TCS. It should not cause a problem other than the trouble code.
PhatQ45
Car: 95 Q45
qsiguy wrote:The cooling fan issue is irrelevant to this post. It is a minor issue with using an older ecu with a newer Q. The trouble code is as Brian stated, you have an ecu for a TCS car and you don't have TCS. It should not cause a problem other than the trouble code.
The small black fan in front of radiator didn't come on at normal operating temprature. At what temperature this fan turn on? I guess my 95 cooling fan doesn't work with 93 ECU equipped with TCS
PhatQ45
Car: 95 Q45
So my new ECU I bought for $20 didn't turn on cooling fan but everything else work fine. Humm... how to fix this problem?? I dont want spend too much time rewire (not a wise idea i guess). I cut the wires connect to fan motor and wire it to constant power source. Now the cooling fan always on when engine is running. Problem solved
