ECU Question
S13Silvia917
Car: 1990 240SX
Guys i have searched the boards and google but just cant find an answer... why is it that my ecu is #78 and it seems like everybody else is using #98?? Do I have the correct ecu, I have a 5-speed if it matters. Thanks
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
does your car run and drive?
S13Silvia917
Car: 1990 240SX
MeanGreenS13 wrote:does your car run and drive?
it did for like a month (then my stock maf went out which leads to another story,i got a z32 maf and safcII and never again did it run right)
MeanGreenS13
when it stops all this BS outside, ill look at MY ECU. i believe very much that its a 98 tho. i could almost PROMISE you that it is. i dont know much about ECU numbers and such on these cars, I am using Emanage BLUE on my car, i would never run an AFC again, they dont control timing, and thats a big point with a CA.
S13Silvia917
Car: 1990 240SX
anyone else have any input on this??
MeanGreenS13
i am running 98..
float_6969
It's probably just and automatic ECU. They work just fine. No speed limiter is the main difference.
S13Silvia917
Car: 1990 240SX
float_6969 wrote:It's probably just and automatic ECU. They work just fine. No speed limiter is the main difference.
yea i tried searching as that was one of my hypothesis...you say they work fine but will a 5 speed run better are both exactly the same??
