ECU question
Papasmithnc
Car: 1994 j30, 1994 Mitsubishi 3000GT, 1995 BMW 325i Vert
I was looking at the instructions for reading the diagnostic codes for my 1994 J30. They are as follows.
1. Turn ignition On, but do not start engine.2. Using a small screwdriver, turn diagnostic mode selector switch, located on side of ECU, fully clockwise.3. Wait two seconds, then rotate switch to full counterclockwise position.4. A malfunction code can be read as the long (0.6 second) blink, indicating the first digit of a two digit number and the short (0.3 second) blink, indicating the second digit.
My question is in regard to the third step. How do I get to the diagnostic mode selector switch in step number 2?
I understand that the ECU is under the kick panel on the passenger side. However, I see no screw readily apparent. There is a cover that looks like it covers the guts of the ECU but a couple of the screws to take it off are hidden. Do I have to somehow take this cover off to get to the mode selector? From the description of the process, it sounded like this would be a piece of cake.
Thanks,Dave in NC
gr8scott72
Car: 1994 Infiniti J30t
Papasmithnc wrote:I was looking at the instructions for reading the diagnostic codes for my 1994 J30. They are as follows.
Thanks,Dave in NC
You have to remove the ecu before you can see the screw. Once you take it out, it will be obvious.
xxcrashxx
Car: 95 Infiniti J30
wow, dont feel bad, i was hoping thats what this thread was about.. i couldnt find that screw either, thnx to gr8scott72 i got a better idea now... lol
yodawill2000
Car: 94 Infiniti J30
Yup.The stuff you need is facing the front of the car on the ecu.Would have been nice if they mounted it on the side.
