ecu question...
zero_gripS13
Car: soon to be 95 s14 hopefully
hello i am getting ready to do my swap and i was curious i ran the numbers on my ecu and found out tits a automatic ecu..'
now i dont think this is a problem but what do you guys think.. this is a manual setup..
number is 2371m-36f11 (its a remanufactured nissan ecu incase your wondering... weird huh.... )
do you think ill have any issues running this in a manual setup?
capowered240
Car: 90 240sx
zero_gripS13 wrote:do you think ill have any issues running this in a manual setup?
No, you shouldn't.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
there are lots of people running auto ECUS instead of manual.
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
If you plan on upgrading your MAF or injectors via an ECU ROM tune, it wont matter at all, you can find a manual ROM file and put it on there. In the end, no, you should have no problems with an auto ECU.
If its similar to the SOHC KA ECUs, then the auto ECU already has the speed limiter removed.....
float_6969
Auto ECU in a manual is fine. I've done it multiple times.
zero_gripS13
thanks guys i figured since i run an auto ecu in the ka now (ka24de) but i just was checking since i just noticed when i ran the numbers that it was an auto ecu..
i am excited motors going in here shortly...
