ECU Question
hexfactor
Car: Cars, Women, Computers
When you disconnect the battery in a 1990 240sx Fastback for a long period of time, does the ECU (computer) need to relearn its settings for Timing/ Ignition? Does driving it around help it learn its settings? I am a newbie plz have mercy :-)
-Chris
U12 2NR
when the battery is disconnected, the ecu loses it's stored data...but that doesn't mean it doesn't have any information to keep your car running properly. there are default settings that are applied. Yes you do need to perform relearn procedures. just warm the car up to operating temp and take it out for a gentle drive, bring up slowly up to 60mph and then bring it down, repeat a couple of times and the ecu will adapt to what the sensors are telling it.
hexfactor
Thank you soo much for your reply this helped me greatly to fix the problem of the sputtering. I appreciate your advice.
-Chris :-)
Q45tech
Think of the learning as the ability to change the permanent memory values [correct timing and injection duty cycle for a brand new engine at 68F and sealevel by a maximum of 20% in response to the average values returned by the O2 sensors.
Normally the fuel trim correction is +-10% depending on temperature of air/altitude and injector dirtiness.
The learning is pretty fast after you get to cruise a minute or 2........usually WOT is not affected by the cruise memory trims as these values are calulated by MAF voltage.
hexfactor
thanks for your input! :-)
