From the old faq. look for ecu in the old faq in my signature.
1. Accessing to the ECU
The ECU is located to the right of the passenger footwell. You need to remove two fastener of the right doorstep in order to remove the kick panel. To remove the plastic fasteners, unscrew the center part and pull out the other part. Two metal screw and a fastener hold the kick panel. Some kind of pitch is also present.
Under the panel you now see the ECU with its connector. Unfortunaly, you have to access to the other side of the ECU. Unscrew the unit and turn it 180 degree on the vertical axis without unpluggin it.
You now see the front of the unit. An ajustment screw, a green inspection lamp and a red one are present. The screw is use to adjust the idle speed and to change the diagnostic mode.
MARK THE ORIGINAL POSITION OF THIS SCREW. UPON DIAGNOSTIC COMPLETION, RETURN THE SCREW TO THE PREVIOUS POSITION. OTHERWISE, ENGINE IDLE SPEED MAY CHANGE.
2. The ECU modes
The electronic control unit have five mode:
Mode I- Exhaust gas sensor monitor (Normal mode)Mode II- Mixture ratio feedback control monitorMode III- Self-diagnosticMode IV- Switch on/off diagnostic systemMode V- Real-time diagnostics system.
The unit automatically return to normal mode I when the ignition is switched off.
Only mode III will be studied here. Troubles code are stored on mode III. The stored codes will be lost if the car battery is disconnected or if after selecting mode III, mode IV is selected.
3. Changing to mode III.
- Turn the ignition 'ON'- Turn the ECU adjusting screw fully clockwise.
The inspection lamps will flash onces, the unit will be in mode I. The inspection lamps will flash twice, the unit will be in mode II. The inspection lamps will flash 3 times, the unit will be in mode III. The unit will continually cycle through the five modes until the screw is turn back.
- Turn the screw back after the lamp has flashed 3 times.- You are now in self diagnostic mode III.
4. Reading the trouble codes.
The codes are indicated by the number of both red and green lamps. First the red lamp flashes and then the green one. The red lamp correspond to units of ten and the green lamp to units of one. For example, when the red lamp flashes once and the green lamp flashs twice, this signifies the number "12".
The codes are:11 Crank angle sensor circuit12 Air flow meter circuit13 Engine temperature sensor circuit14 Vehicle speed sensor circuit21 Ignition signal missing in primary coil31 E.C.U. (E.C.C.S. control unit)32* EGR function33 Exhaust gas O2 sensor circuit35* Exhaust gas temperature circuit43 Throttle position sensor circuit45* Injector leak55 No malfunction
*California models only.
After the diagnostic, Turn the ignition 'off' to return to mode I.
To erase the memory, use mode IV. The codes are automatically erased from memory when the starter is operated fifty times after the trouble is last noticed.
Hope it will help.
Richard
[email protected] city, Quebec, Canada
