In reference to this thread:
zerothread/159644
I'm having a similar problem in which when I turn on my car the fuel pump does not come on and it won't start. After reading that thread I figured that my ECU was bad and so I took it out to check and see if anything was burned out. Nothing was and so I stuck it back in and everything seemed to work. I took it for a short drive with no problem.
However, just a minute ago I was driving it and it stalled out and now the same thing is happening again (no fuel and no start). I'm not sure whether or not my ECU is bad because sometimes it seems to work and sometimes it doesn't. Is there a definitive way to check and see what the heck is going on here? I'd like to know if I need to get a new ECU or if it is something else entirely. Thanks.
By the way, I know for sure that it is not my actual fuel system that is the problem.
