ECU question.
Slappy
Car: 1993 240 sx coupe
Modified by Slappy at 10:31 PM 9/13/2007
onosqv
Car: '92 240sx Vert
Get one from a 91-94 and you'll be ok. Get an auto ecu & you will get a slightly more aggresive fuel map & remove the rev limiter (easy cheap upgrade, found out from other posts - seems to work for a lot of guys).
Nismo_Freak
Car: 89 Nissan 240SX
You want to get the same year ECU, but you can make others work.
Hitting the speed limit early might be a speed sensor failure.
