ECU Question, Need help!!!
93DriftMachine
Car: 93' Nissan 240sx
Does the check engine light have to be on for the ecu to throw codes. I am having problems with my MAF. After I cleaned it with brake cleaner the car started having idle problems and would die at stop lights. It was running very rich. After I came from vacation the car doesnt surge as much only minimal from 500-800RPM but now the car runs sluggish. Thanks for the input.
sunnys14
Car: S14
you probably killed your MAF when you used brake cleaner to clean it. the MAF is really sensitive. use electrical parts cleaner only.
93DriftMachine
Thats what I think it is. Sure enought, it was my MAF. I got a used one from a friend and now it runs fine. Thanks for the info.
