ecu question about j4 and 62 and fuel rail not getting any gas threw
morgasmo
Car: 89 nissan 240sx
i bought a red top sr20det and it came with a j4 ecu but the ecu was cracked so i just bought a new one but its a 62!. would that stop my car from running??? cause my fuel rail isnt getting any gas out of it when i crank it
Modified by morgasmo at 11:33 PM 3/27/2008
SpeedRacer1
Car: 1990 240SX, G35
They are unrelated problems if your fuel pump is priming. Perhaps you reversed the fuel lines.
morgasmo
its reading now i grounded my injectors and it starts now but it doesnt stay on cause i need to do the timing but how do i do the timing???
morgasmo
also im not sure if the reason that it wont idle is that maybe it has a really big vacuum leak, or if the regulator is not pushing enough pressure or too much. How would a go about checking the regulators pressure and also were are all the vacuum lines besides by the throttle body area??? it is a red top sr
skaterfromvt
Car: 1989 240sx sr20 blacktop Built not bought 87 v8 rx7 fc3(50) 95 s14, 00 dodge ram 1500
how exactly did u ground ur injectors...i swapped to an e5 ecu in my black top and with the e5 ecu i cant get any fuel to my fuel rail but i can get it with the old ecu?
3 of the 4 injectors fire with old ecu and
None fire with my e5 ecu? any ideas?
