need2drift »
https://forums.nicoclub.com/need2drift-u12175.html
Thu May 25, 2006 4:08 pm
when you remove the ecu top is there a big board with the 40 pins discribed right there near the top of the ecu, but not on the actual ecu board?? if so then yes it is tuned, under the daughterboard[the thing with 40 pins] there should be two eproms, little rectangles about 1/2" by 1 1/2"... if there are no eproms under it then its use less..
