ecu problems
firstwizardshawn
Car: 1990 NISSAN 240SX
i have done everything i can to get this thing started it is either soomething with the fuel (which i think is ok) maybe injectors are stuck. but the last option is that the ecu has something wrong with it! so my question is does anyone have an rb20det ecu manuel lying around that they want to get rid of?
thanks firstwizard
Carl H
what exactly is the car doing...since you are having so many problems with just getting this car started im thinking that the wiring is the issue.bad wiring can torch an ecu with the quickness.
mello88
Car: s13
You didn't put any symptoms.. Sorry if u put this on another post but,
Does it crank?Are the plugs wet with fuel after cranking?Do you have spark on all cylinders?Is the timing set correctly?Does the ECU have codes stored?Do you have power to injectorsDo you have power to ignitor?
