RED_DET wrote:I would start with a simple fix of the crank angle position sensor. Common issue and gives the same symptoms you described. The part cost $20-25 @ any auto parts store and can be replaced in about 1hr or less. If the ECU is bad, which they are known for that as well, you will have to match the code off your ECU to make sure you get the right one. You will have to remove the ECU to get the code. If the car has less than 80k miles and was put in service less than 8 yrs ago, the ECU is covered under the emissions warranty of 8yr/80k miles. Just food for thought if you fall into that category. If that is the case, Nissan would be responsible for replacing the ecu, which I had one on my wife's car.
