Ecu or BCM stores mileage?
SnowNYC1
Car: 2006 Infiniti M35x
2011 Infiniti M56x
Hey guys,
so i came into possession of a 2011 M56x with one issue.... swapped cluster without the miles reprogrammed.
I was wondering if it was possible to pull the correct mileage from the ecu or bcm so i can match up (roll up) the odometer for inspection.
is there anyway to pull the mileage info stored on the bcm or ecu?
any help would be appreciated!
Ilya
As far as I know, the cluster has the mileage. So you need to reprogram the cluster to read what the other cluster read or what not. This has been the case on every 'digital' Nissan/Infiniti cluster I've ever dealt with going back to the late 90's (Maxima's).
SnowNYC1
2011 Infiniti M56x
so if i take it to an emissions inspection with the original cluster which is missing like 10k miles on it because of the replacement no error would pop up on the computer?
Ilya
While most likely fraudulent lol, technically, I believe that to be correct.
Sstupid
Car: 2007 Infiniti M45 Sport
On my old Cobalt, the BCM (little black box) kept the mileage. Mine went out and was replaced under warranty. I just assumed it was true for all OBD2 cars.
hagani
Car: 2008 Infiniti G35x
2012 Infiniti M56x
SnowNYC1 wrote:
Thu Jan 25, 2018 10:52 pm
Hey guys,
Canadian one?
