ecu=no power
1SlowCA18DET
need help, yes i've searched, didn't find right answer. how to check if ecu is getting power?
sdtouge
Car: 1990 240sx coupe
if it light up when the ignition is on it has power, you can check for codes and stuff
float_6969
There is a place in the stickies at the top of the forum that you can download a copy of the FSM from. In there you will find a wiring diagram that should tell you everything you need to know.
