ecu mods
DOHCscreamer
how can i advance the ignition timing? will infiniti do it for me (i remember some nissan dealers would do it for you on the altima with the 3.5). how many degrees should i go? i always use 93octane and i live in hot texas.
does anyone make a piggyback ecu?
i have the 2005 g35 sedan 6mt
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
There are a few piggybacks available. Greddy Emanage Ultimate is one of the most popular. Nissan/Infinity can advance the timing, but they don't actually "advance" the timing itself, they advance the baseline setting. This will work at lower RPM's, but at high RPM's and WOT, the timing is variable, and controlled by the ECU. Those settings you would only be able to change with a ROM emulator, and reprogramming.
DOHCscreamer
beancooker wrote:There are a few piggybacks available. Greddy Emanage Ultimate is one of the most popular. Nissan/Infinity can advance the timing, but they don't actually "advance" the timing itself, they advance the baseline setting. This will work at lower RPM's, but at high RPM's and WOT, the timing is variable, and controlled by the ECU. Those settings you would only be able to change with a ROM emulator, and reprogramming.
about how much would the dealer charge for the advance? i would like this since 90% of my driving is under 3500RPM. i'll look up the greddy piggyback. thanks
DOHCscreamer
after looking at that greddy, i think its a little more than what i am looking for. i thought stillen was working on a simple piggyback for the vq at one time? it was going to be simple (slight fuel changes, ignition timing, keep throttle fully open). thats all i want. i guess i'll go to the dealer for the timing advance.
Gimli G35
Car: 1996 Lexus ES300
i actually like UTEC because it is a simple snap on piece instead of hard wiring it
and keeping the throttle fully open is hard programed into the ECU , you will need to ship your ECU and get it reflashed ... they can remove the RPM limit .. The Speed limit and tune your car for NA \ FI applications ...
As i said to the PCM Flash thread...
Alot of people like to reflash the ECU for those reasons but also get a UTEC for changing the tuning
Focusedintntions
Car: 07 Infiniti G35 Coupe 6mt
Do they not make like a SCT flasher or Xcal for the G? I had one on my SVT focus and made a wonderful difference from the factory tune and only took like 10 minutes to do.
DOHCscreamer
back to one of my original questions...my car has no engine modifications. how many degrees can i advance the base timing? (1, 2, 3 degrees)?
Gimli G35
absolutely no idea .... no experience = no advice
