ECU limits the fuel intake after modding? catback exhaust. I started reading va
Streets_of_Fire
Hello! I have an intake, headers and 2.5. my check engine light came on after the headers due to the EGR not functioning. I also read that nissan's ECU's limit fuel intake when the check engine light is on? Is this true? If so, then wouldn't taht harm the engine and performance? thanks
Streets_of_Fire
i gues this is too techniccal for you guys? =/
fgski8118
Car: '89 240sx, 100% emissions removal, electric fans w/dif
if you are running to lean, it can cause pinging. but your ka has a knock sensor that if it is working properly will retard your timing to prevent damage. you would know if this has happened because any perforance you had would go out the window. your car would feel very under powered. have you fixed the egr problem?
Streets_of_Fire
nope. its not possible. with the headers, the exhaust flows too fast that it does not have enough flow to open the egr valve. i doubt anyone has normal functioning egr after installing headers, its the main reason its not smog legal right
