ECU leveler?!?!
govtworkhorse
Car: 95 240sx SE, 95 240SX, 91 Festiva (DD), 03 GSX-R 600
I know this sounds crazy, but all the problems I had with the car over the last week have just been solved. By standing the ECU on it's side and not lying horizontally. now tach, temp, fuel, speedo work. Car idles better. Doesnt lack power like I have a boost leak. All the plug wires are tight so I'm curious if the ECU has a leveler type deal in it.
Cjmartz2k
Car: Hunting for a '89 GTR now
Sounds like you had a loose/shorted wire that you moved.
govtworkhorse
that what i figured first but i checked them and they seem to all be secure. odd...
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
yea sounds like loose wire(s), plug, etc.
I bet if you let the car run/idle and wiggle the wires coming from the ECU it'll see those initial problems once again.
Joe
you have a loose connection
electrical circuitry doesnt care what direction its sitting.
govtworkhorse
I know I know. But I thought I'd ask
240z4u
Car: '95 Nissan 240SX
govtworkhorse wrote:I know this sounds crazy, but all the problems I had with the car over the last week have just been solved. By standing the ECU on it's side and not lying horizontally. now tach, temp, fuel, speedo work. Car idles better. Doesnt lack power like I have a boost leak. All the plug wires are tight so I'm curious if the ECU has a leveler type deal in it.
Yeah, its like a tilt thing on a pinball game LOL.
Any chance you grounded the case of the ECU to the body when you turned it? That could do it too.
Evan
govtworkhorse
No, I had the ECU way from the body because I was still working out problems and hadn't "tucked" it yet. Everything seems to be fine now but I keep getting gas in my oil. Checked compression today and its 145psi across the board so it's not my rings. This is the last thing I have to fix whoo hoo
Joe
how much gas?
does your PCV work?
govtworkhorse
Well there was a strong fuel smell last week so I changed to oil after install. The car has run for an hour tops to work out bugs and has used a 1/4 tank of fuel and I noticed the oil is thinner and wreaks of fuel again, I drained it earlier and refilled but didnt change filter this time or run it since. Is it possible for a boost leak to cause this? I ran it for a few minutes to load car on trailer, swapped motor, changed fluids, popped coupler and had to run it for a few to get back to my house, now fuel in oil again. Going to check injectorss and coolent temp sensor in the morning.
govtworkhorse
How do I check the PCV? I just searched it on the forum and in the FSM but nothing really clear.
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
Are you sure your Gas return line is working properly? Or that its not clogged up?
240z4u
Sounds like leaky injectors to me.
Find the problem before you trash your motor though!
Evan
rb25drag
Also if you have gas in the oil and you just change your oil and not the filter you have not cleaned the gas out. Be sure to change the filter too.
Coolwhip
Vendor
yea, leaking injectors might dump fuel on top the the pistons and allow them to leak gas through to the oil.
