sycamore wrote:the led light just stays on all the time it doesnt turn off... is it just a bad ecu or is there some magic trick you have to do... i dont know any thing about 240s this is not my car im just trying to help him out so take it easy on me thanks
Holy run on sentence batman!
First start by dumping the code on the computer.. Then once you determine what the code or codes are then refer to the list of codes to find out why the light is coming on. The steps to reset the ECU and the code definitions are located here.
http://www.240sx.org/faq/index.html
Good luck and may the search button be with you!!
