snobrder wrote:Grr....I keep getting the 55 code..this is what I do:-Take car for spin-Turn car off-Put key in and turn it to just before starting so the radio and electronics work.-Turn nob once on ECU and read codes.
snobrder wrote:Can anyone tell me if I am doing this right?
With 2 dead injectors and dead KS you should have stored codes. Is the CEL illuminated on the dash?
Here's the sequence:> Make sure the ECU screw is in the full CCW position. If not, turn it CCW before turning on the ignition.> Turn the ignition to the ON position (the last stop before the starter comes on)> With the key on, the light inside ECU should be solid red.> Rotate the screw fully CW, wait 3 seconds, turn fully CCW.> Read the codes
> To reset: Turn screw fully CW, wait 3 seconds, turn screw fully CCW.> The red light will now be solid, rotate again and it should read 55. If you have dead injectors, bad KS and a continuous or intermittent CEL the codes should return after a few moments of driving.
Don't leave the ECU in the flashing position and start the engine. You need to rotate the screw one more time to clear the 55 code and get the light solid again (This may be what you're doing wrong?).
Q45tech wrote:No codes created for fuel system [pump or fpcu] pressure or flow rate.
The fuel pump is a whole different issue that can be tackled next. With the trunk lid open are you hearing what sounds like a swarm of bees? It wouldn't be a bad idea to check you're fuel pressure but at this point replacing the 2 easy-to-get-to dead injectors and pulling codes seems like a good start. The engine will run a lot better on 7 cylinders than it will on 5.
