slideways_240 »
https://forums.nicoclub.com/slideways-240-u155232.html
Sun Apr 18, 2010 5:52 pm
ok, today i pulled all of the harness out of the car that plugs into the ECU and cluster. i had 3 wires that were messed up. the first wire was the detonation sensor 1 {cyl 1-3}, this could be my breakup problem.next was the air flow meter intake air quantity signal wire.and last was the battery power supply wire, this one was apart when i got the harness out through the firewall. the wire was green from corrosion.when i did the swap some of the wires were cut from someone pulling the engine. i used a fluke meter and checked to see if the wires for the relays were ok and they checked out.does anybody think this could be my problem???? next im gonna check the maf wires.
i found two wires that sit in the harness by the iac that are blue and light green, they go to the plug for the plug for the cluster. there is no plug on these they are just wires. any ideas??
