sr28 wrote:Not sure where the problem is yet, every few months my fuel pimp refuses to prime. In that case I pop the ECCS relay out and put it back in and the thing primes. well eventually this leads to my ECU burning out. the 4th pin black/red which goes to the ECCS keeps burning on the ECU making it useless. It burnt out in the same spot on the ECU twice. what could be causing this an open wire or something?
I'm trying to visualize this and here are a few things I'm thinking.
-The ECCS relay is controlled by providing through the ECM (I'm 99% based on year/model, but that's how they normally work) and if that is the wire that is burning that mean something is backfeeding power to the ECM
-Have you ever tested or replaced the relay? For both operation and resistance?
-If the "fuel pump not priming" is caused by no fuel pump relay operation then I would look into the wiring in the circuit. It seems highly likely that you have a compromised ground somewhere in the car or some altered wiring that has effected the ground.
If you are skilled with a multimeter you can perform the necessary tests if not you may want to find a specialist.
