ok ...this is on my 95 ka ... it all started when the engine check light came on and i figure out form reading the ecu code that my Air Intake Temp Sensor was busted (1 of the 2 wires broke off). from reading i found its only used for diagnostic purposes and many people drive with it disconnected but usually have the cel stay on. from looking at ecu pinout diagrams, ive located the AITS wire (#63) and am wondering if i want to eliminate that AITS, can i just cut the wire?
since the AITS has been "busted", ive noticed my 240 has been acting a lil wired down in the lower rmps as if its almost bogging... but im not sure if its cause i was low on gas.
http://www.az240sx.org/tech/Pi...T.xls
Now, i have also have a sparre 97 auto ecu that i was hoping i could install to eliminate my rev/speed meter but soon found out that the main harness is bolted to the 5spd ecu VS the harness of an auto uses a Nut to hold it to the ecu. is there a female and male version of the auto ecu's??? or can i just take the bolting device out from the main harness, plug in the auto ecu and just zip-tie the harness in place???
any help is appreciated! thanks!
