zach-Ka »
https://forums.nicoclub.com/zach-ka-u78727.html
Mon Jan 19, 2009 4:21 am
Well I just followed the steps in a random thread I found while searching nico. Which was to look at the light on the ecu when the key is turned, just before actually cranking the car. Well I just recently did a sr swap And when I wired the Mafs up I accidentally wired the power to the signal and the signal to the power. At first I thought I fried the mafs after realizing what I did. So to make sure I tested it on my friends ka-e and it worked fine. The wires seem to be fine. One day while searching nico I stumbled across a thread that said faulty wiring on a mafs can send a ecu into limp mode. And thats pretty much where I'm at now. I have checked the volts on the TPS and I have gone over my vacuum lines i don't even know how many times. Im about to go look for the faq/tech article to see if there are any differences in the procedure.
