canadiandrifter240sx »
https://forums.nicoclub.com/canadiandrifter240sx-u38452.html
Tue Dec 19, 2006 12:34 pm
The POT is for self diagnostics. There should also be a L.E.D somewhere usually right beside the POT. If you turn the "POT" full clock wise and back a quarter turn then the L.E.D will start flashing, it will flash short flashes first then long ones ex. - - - - - 5 short flashes = 5? which is the first diget of a 2 diget #, if after the short ones you -- -- -- -- -- 5 long ones then that is your second diget which = 55. Code 55 on all the Nissans I have worked on mean that there are no trouble codes ( everything ois fine), code 13 (1 short, 3 long) is the code for faulty C.A.S curcuit.
Chris
