make sure tachometer meter needle moves when cranking. if not, connect a timing light on each wires and check flashes of light for weakness. check ignition wire resistance. replace bad wires. or just replace them all including the plugs completely to quickly eliminate them as the problem. check your power transistor and ignition coil:
