rkleff »
https://forums.nicoclub.com/rkleff-u180572.html
Tue May 10, 2011 8:13 pm
I was getting Code 34 Knock Sensor and after finally getting a good multimeter, I was able to get them to ohm in spec from the pins to the negative battery terminal. But still I was getting code 34 using ECU Talk so after seeing the above post about grounds, I decided to work on my grounds. I had already cleaned the negative battery terminal, but when I went to disconnect my negative cable to frame ground, I snapped the bolt. I had put Liquid Wrench on it but only waited about 30 minutes and did not tap the bolt to free it. I had to drill and tap a new hole in the frame to reconnect the ground. I cleaned it with a Dremel with a flexible extension to shinny metal and cleaned the copper tab with baking soda to get it back to copper color. I put dialectric grease on the connection and snugged it up. I also cleaned the C24 ground on page EL 277 of the 94 Q45 FSM and what I am trying to say is that IT WORKED!!!!!!!!!!!
I no longer have a code 34 and I no longer see my timing retard to single digits when I put a load on the engine. I am a newbie to the forum and have learned so much that I would like to thank everyone for their contributions.
rkleff on Wed May 11, 2011 9:22 am, edited 1 time in total.
