veilsideS14 »
https://forums.nicoclub.com/veilsides14-u3365.html
Mon Apr 14, 2003 3:20 am
Hey all. I'm wondering if anyone knows the correlation between the ECU, fuel pump, and fuel injectors on a BCNR33 GTR engine. More specifically, if the ECU doesn't see any connection to a fuel pump, will it deactivate the injectors? (i.e. ECU doesn't sense fuel pump = ECU doesn't work the injectors?)
I know that like the Z32, the RB26 fuel pump is controlled by the ECU unlike the Silvia which is chassis powered. I was just wondering since it's ECU controlled, will it do funky things to the injectors if the ECU doesn't see a pump hooked up.
Thanks!
