Ecu fried
charmessence
Car: 1997 Infiniti Q45
The ecu on my 97q is fried and I need some advice on replacing. I do understabd I need to match the pt numbets but I am confused to if it needs to be reprogrammed by the dealership before replacing. I can easily replace it myself but have seena.few comments on reprogramming along with my keys needing to be reprogrammed as well. Also i now i need a new IAT sensor and crankshaft
charmessence
Additionally, I am a bit confused as what part # I need for the 97q45 i see several on ebay. The info on vehicle is 09/96. The info I see on my ECM is:
47850 6P100
A48-100 P01
Info underneath hood on fuse box is- 24382 6P100
Vehicle emissions ctrl - 6P600
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
47850 6P100
where did this number come from?
this is an ABS module.
you said ECU. Which is it?
how do you know its fried?
charmessence
The # came from the actual ecu in the car as of now. I saw the # after detaching the glove box and locatit it. When trying to read codes from the unit it doesn't provide anything or respond at all
Q451990
Yep... that definitely looks like the P/N for the ECU. If you haven't checked out your car's factory service manual, it would be worth it to help you in locating the ECU. www.infinitiservicemanual.com
charmessence
Thank you sir!
charmessence
Also, will i need to have the ecu and my keys programmed at the dealership or is this something I cam perform manually?
Q451990
That's a good question, and one I don't know the answer to for sure... I think many locksmiths have the tools to register keys to the ECU, so if you find that you need professional help in that area, I would look to them too. It would probably be cheaper than a dealer.
charmessence
Thx Q451990! The dealer is charging $135 for reprogramming only no installation, so thats not too bad. I will call a locksmith to get their price as well.
charmessence
Think I just confused my self everyone....took out glove box and puechased the ecm part ( not sure of its ecm now) with the part number poated above. The part i purchased is listed below, first link. As i remove the passenger kick panel I see another portion of which i think actually maybe the ecm (in second link as im unsure how to post pics). Which is the ecm?
First link of what i purchased:
http://pages.ebay.com/link/?nav=item.vi ... 90&alt=web
Second of what i found behind passenger kick panel:
http://pages.ebay.com/link/?nav=item.vi ... 63&alt=web
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Let's spell out the acronym.
ECU--the E could be 'engine' or 'electronic'. but we typically associate this with 'engine' unless there is more info provided.
U=unit
M= module
why acronyms can be dangerous and I attempted to tell you that the 47850 6P100 had to do with ABS. yes, it *could* be considered an electronic control unit for the ABS.
so is your problem with your engine computer? that is exceedingly (but not impossibly) rare.
how do you know your intake air temp sensor has issue? from an engine control unit code? if you have code P0110, first check that the connector is mated, then check for a broken wire---which is very easy to break considering that intake piece gets removed frequently to work on the top/front of the engine.
charmessence
Thx for the response! Yes when I was able to get any codes, as now im unable too which leads me to believe the engine control unit is bad, i did get p0110 p0335 and p0161.
