rivetapproved240 »
https://forums.nicoclub.com/rivetapproved240-u10593.html
Sat Apr 17, 2004 3:08 pm
see when you clean your injectors through the break booster line, the car usually stalls out and thats when you stop. well not only did my car stall out, but also was a pain to get it to turn over. and what does a knock sensor do ? i have the 1995 nissan 240sx book i bought from nissan publications for an outrages amount but it sometimes seems lacking. where could i find a air intake temp sensor and a MAF sensor? o an i have aftermarket intake but i have had that on there for a long time with no check engine light. its not homemade it name brand. tried local junk yards for maf and aits, but no luck will any ka24de maf work? how about the same for the air intake temp sensor. i wouldnt mind upgrading to aftermarket maf, but lack of funds is a problem. But Could the 02 sensor cause these sensors not to function properly, i mean i was skimpy and bought a cheap 02 sensor. its Bosch but its the universal one for my car so i had to extend the wire about 3 inch and change out the connecter. i used a tube crimp, shrink tubing, and a regular female connector, and just reused the rubber plug. also dont know if its related, but theres a strange smell coming from the underside of the driver side, smells like hot glue, but its not in the engine compartment. but i did paint my heatshield with high temp paint and some scratch off in the process of putting it back in. i dont know. and suggestions.?
