oneill.s13 »
https://forums.nicoclub.com/oneill-s13-u143867.html
Mon Oct 19, 2009 12:34 pm
My ecu is giving off two error codes, one is a water temp sensor error and an automatic error. I did a DOHC swap and added the SOHC water temp sensor onto the engin, could this be causing this? should i switch it back? also will the automatic ecu work in a manual transmission car?
Im trying to get my car timed and the shop says the ecu wont let the timing set till these issues are resolved, any input would be great.
thank you
