ECU/Electrical problems
mambastu
Hi all,Just coming to the end of my R33 GTS-T RB25DET into S13 conversion and I'm having a few last minute electrical problems. Unfortunately I haven't been able to follow the Wiring sticky because the wiring on Euro spec S13's (CA18DET'S) is completely different to your US spec KA cars. :(
Finished fitting the engine last Friday. Fired it up and it started immediately and ran for about 15 minutes untill it was warm at which point we switched off the engine. Checked all the fluid levels and fired it up again. Within 30 seconds we noticed smoke coming out of the ECU and then the engine stopped running.
Turned everything off and pulled the neg wire of the battery. Opened the ECU and found that a resistor was badly burned (R420) and a transistor (T450) was burnt so badly it had seperated from the board. Bugger
Checked the various connections and everything appeared to be fine although there were a couple of cut wires that may possibly have earthed to the inner wing but we weren't sure.
Managed to get hold of another ECU and tried it today. Plugged it in, turned the ignition key, fuel pump primes for about 5 seconds and 10 or 15 seconds later the same resistor (R420) starts to smoke. Checked all the pin outs on the ECU and everything looks fine.
Has anybody experienced this before and if so how can you tell me how you fixed it please ?
Nameless EJ6
Car: What the **** do you think.
odd! I want to know. bump
mambastu
Found the fault at last. Looks like the engine loom had taken an impact and 1 wire was completely severed and another 3 (including an ignition feed) had damaged insulation and they were shorting. There were no obvious external signs of the damage, we were quite lucky to find it ! :)
