ecu driving me crazy
cny240
ok i got a problem my ecu won't turn on... the ecu relay wont click on at all. but when i take direct power to the black at white wire in the engine harrness it turns on. cheacked to make sure the relay was getting power and it is. so i tested the relay and its fine. i thought i must be a ground for it. looked it up and it grounds threw the ecu in pin 4, and is a red and black wire. i test the wire by grounding it right befor the ecu plug and the ecu turns, and the relay works. a i donno where to go from there. and ontop of all that somehow my fuel pump wont turn on eather even when the ecu is on. im lost and need help
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Check fuses and fusible links...
cny240
i found that on of the wires on the ignition was broken off.. with it connected everything works ecu turns on fuelpump works. but during cranking the ecu shuts off and turns right back on after i stop any ideas
PyR0NiAk
Trace your wiring. I would say you have a loose connection. How did you reconnect that ignition wire? Did you actually solder it?
cny240
yes i did. and found out my cas wasent pluged in all the way. start and ideals high about 1500 and its runing lean think i may be a vacuum leak but im starting my rebuild soon just needed to get it to run 1st. thanks for ur help
PyR0NiAk
No problem. Stick around NICO. ;)
