I gotta get one. I feel like I'm the only one that doesn't have one yet. I've got a huge to-do list for my car and just haven't gotten around to it. Glad to see that everyone is happy with the end result.CrimsonQ wrote:yep, i love mine!! Its no spped racer,. but its sure a hell of alot more fun
Best bang for the $$$
Same as mine I think.. 18x8F 30mm 225-45-18; 18x8.5 33mm 245-45-18lino wrote:BTW what size tires are you running and what is the offset of your wheels?
Have you ever experienced unusual tire wear or rubbing issues with the:18x8F 30mm 225-45-18; 18x8.5 33mm 245-45-18 ?elwesso wrote:
Im going to run 245-40-18 and 255-40-18 (F/R respectively) and I think ill be fine.. However my fenders are rolled all the way around...lino wrote:Have you ever experienced unusual tire wear or rubbing issues with the:18x8F 30mm 225-45-18; 18x8.5 33mm 245-45-18 ?
I don't know why but just a couple of minutes ago the car was idling pretty well.750 in neutral and 750 in park. So.... that's ok by me but still different than what you just posted.RobertsnewQ wrote:Dmitri - Glad you like it. As for the idle, that is a little weird. I'll look at the code again and see if I've changed anything. I sometimes have 5 or 6 variants of the same code but I try to keep them consistent for all the ones I sell.
I can bump the idle back up to 750 easily enough. Does it idle at 600 in neutral, too? Idle is usually 650 neutral/625 in gear or 700/625 (JDM) or 750/650 (1990). I haven't seen a late model like yours with the 750 idle but it wouldn't be the first time they changed something minor.
Won't the diameter be different front vs. rear? 245/40, vs. 255/40.I kinda wanted to put 255/45 on my rears but I thought that with the different diameter it would throw the speedometer off or you'd need to recalibrate.elwesso wrote:Im going to run 245-40-18 and 255-40-18 (F/R respectively) and I think ill be fine.. However my fenders are rolled all the way around...
Email sent.lino wrote:I gotta get one. I feel like I'm the only one that doesn't have one yet. I've got a huge to-do list for my car and just haven't gotten around to it. Glad to see that everyone is happy with the end result.
I'd love to see more pics of your car. Can you make that happen? BTW what size tires are you running and what is the offset of your wheels?
