Post by wrz32 » https://forums.nicoclub.com/wrz32-u163764.html Tue Sep 20, 2011 10:29 am
Post by NolimitZ32 » https://forums.nicoclub.com/nolimitz32-u100070.html Tue Sep 20, 2011 12:32 pm
Post by marty1mc » https://forums.nicoclub.com/marty1mc-u151866.html Tue Sep 20, 2011 2:37 pm
I am not sure what you mean by "not cutting power" to the injectors. The early style harnesses (pre-94) had +12v at the injector constantly. The ECU provided ground and caused the injector to fire.wrz32 wrote:so i found out my ecu is messed up by not cutting the power to the injectors, and that cause my first piston to flood so much that it spills gas thru the end of the exhaust.... i have another ecu but it has a 29 on it and the one on my car is BE, does this matter. if so i found another BE if i get it does it need to be reprogramed... help plz
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
