Ecu diagram
Discussion forum for the Infiniti JX35 / Infiniti QX60 - This 7-seat premium crossover dominates the class.
walo897
Car: G37 journey
Does any one have a diagram of the ecu my fans don't work I changed relays fuses even fan assembly the only way it works is if I added ground to the main relay with a switch basically the fan is on all the time, yes the temp does read so I don't think it's the temp sensor
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
What year G? It should be here in the FSM's, but we can't point you to the right diagrams without vehicle info.
walo897
Car: G37 journey
Lol my bad was still drunk this morning it's 13 jx35
VStar650CL
Technical Expert
Description of the fan system is on EC-49, ECM pin reference starts on EC-95, wiring diagram starts on EC-120.
https://www.nicoclub.com/service-manual ... 3%2FEC.pdf
It's a DC fan with PWM-control and not a true brushless e-Fan, so there's a good chance your Fan Control Module is simply shot.
Return to “Infiniti JX35 / QX60 Forum”
