ECU diagnostics?
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
sinfiniti
Car: Z32 (soon VH45DE), 1971 Datsun 1600 P510 (SR20)
HI,anyone got the corresponding "trouble shoot" to the engine code '54' as in i turned the srcew dial on the ECU to run diagnostics and '54' (5) and (4) flashes came up. only this no other codes.
a list off all codes would be great but just that is sufficient. cheers
Raxephon
Car: '04 RX8...for the moment...
Here is a summary of ecu codes
sinfiniti
thankyou.... hopefully this will solve my (increasingly) large headache!besides i was beginging to worry it could be something much larger!
Raxephon
sinfiniti wrote:thankyou.... hopefully this will solve my (increasingly) large headache!besides i was beginging to worry it could be something much larger!
You're welcome.
Hopefully you'll get a consistant code "55", which is normal/all clear.
sinfiniti
no good... i cant trace/find the wire/wires/plug at fault. any wiring diagrams available. or colour codes to look at?... by what the above troubleshooting chart says..."signal curcuit from A/T control unit to ECM" dooes it mean the A/T computer (found in drivers side kick panel) to ECM(asin the ECU?) or something else, is ECU electronic control module?im not too sure what i should be looking for?Cheers
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Check that TCU is definitely well seated in its socket. Run the daignostic in the FSM. How does your turbine sensor look? Any leaking? Not sure if this will throw a code.
Raxephon
Q45 ECU/ECM (Electronic Control Unit/Module)
Raxephon
Q45 TCU
Raxephon
Maybe this will help.
ECU DiagramTCU DiagramECU Pin-out zerothread?id=199947
sinfiniti
yeah still no good on the VH.cranks fine, still gettingg the fault code "54"
Return to “VH45DE / VK45DE / VK56DE Forum”
