ECU cut on crank
Eragon240
Car: 1991 Nissan 240SX S1 RB25DET
having an issue where whenever I crank my ECU will lose power. all of my connections seem good and I have no issues with ECU power until cranking. Are there any usual culprits of power draw that I should check first?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Sounds like either your battery doesn't have enough CCA to crank or you have a bad connection someplace in your cabling.
