ECU curiousity.
JMerritt
Car: 1992 Nissan 240sx SE
What is the top speed that the stock ECU cuts out at in a 1992 stock 240sx SE?And besides buying a performance ECU, is there anyway i can take it off? And why does the 240 tach out at 5000 rpms in 5th gear, and how can i change that?
mkory
Car: Mazdaspeed Miata
Search my friend... it's been covered numerous times many moons ago.
JMerritt
ok, well you could have just told me the answer to my question, or redirect me to a similar thread if you were going to take the time to respond....but i did look, i looked at like the past 6 pages, and i figured that if i didnt see a post about it by then, then i probably wont, so i made a new one. thanks for the help.
Modified by JMerritt at 11:26 PM 5/27/2005
mkory
It's not that I was being rude, but I looked into it myself too. Then, I decided that I had no business or need to go above 120mph... that's just too fast. There's a wire you can cut going into the ECU. Follow the speed sensor wires on a wiring diagram, you can cut it there but you should still get a speedometer reading as the wire goes into your gauges first. You also might wanna put it on a switch if you have cruise control, so you can retain that too.
JMerritt
thanks
Kaioshin1982
Car: Not a 240 =) Thinking of getting one again...
I heard that ur speedometer dont work if you do that in 5th gear.... but anyways...If your car is 5spd, you can swap in a auto ecu and you get no speed cut but you do lose your reverse light.
