ECU compatability
Dattebayo
Clean and simple, I think I remember reading somewhere that it was possible to use a KA ECU with the SR engine. Someone tell me if i am wrong please.
SpeedRacer1
Car: 1990 240SX, G35
KA ECU's can be reprogrammed by Jim Wolf Technologies to run the SR. However I am fairly certain that you will then have to change over to a distributor.
BuudWeizErr
JWT retune, SR20DE distributor.
It gets rid of the coilpacks and the crank angle sensor
EDIT: And it sucks.
Dattebayo
okay thanx ill make sure to get the silvia ecu then. Its not woth the money for a retune...
Edit: just a question though, does the silvia ecu plug into the 240's harness? I know im gonna have to get the adaptors for the engine.
quiksilvia
Car: 95 s14 se
what do u put in place of the cas if u did the retune? j/w
2bn-are u not using the sr harness?
S13240
quiksilvia wrote:what do u put in place of the cas if u did the retune? j/w...
Distributor cap + rotor
Dattebayo
No, i am most likely going to buy the harness adaptors that i have seen sold on a few sites around. But that wont be for a while now, i have to put the engine together first, as i have gotten it piece by piece. (its a complicated story)
That question kinda confuses me. Isn't the KA harness and the SR harness very similar? Why would i want to take out a whole freakin harness when i can just use the perfectly good one thats in my car now? Or am i worng... Sorry, i just dont wanna fool with it unless there's a good reason.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
The farther you get away from using a stock SR20 harness the more complex it will become and the more problems you might/will run into. Do the right thing, buy a uncut SR20 harness and get the wires lengthend and a few plugs changed.
just my opinion
-matt
Ace
Car: S14
They are similar but they have different style plug connectors. Not to mention that the SR uses coilpacks and CAS and the KA doesn't have those plugs. You need to cut and sauder some plugs from your KA harness to your SR harness.
Lets just put it this way you need a SR harness. So fork over the cash and do it right.
SpeedRacer1
The SR will not run until you have the SR harness.
