ECU codes
vis213
is checking for codes on the ECU same process as say the KA? and are the codes the same as well?
rico05
Car: 1992 RMS13 w/ CA18DET
zerosearch
This has been addressed MANY MANY MANY times.
vis213
i didnt ask how to check for codes i was asking if the process is the same.and searching did not come up with an answer for me
F3600
the process is the same and the code arent the same
iliketocrash
vis213 wrote:i didnt ask how to check for codes i was asking if the process is the same.and searching did not come up with an answer for me
well umm if you look and the process looks the same then it is... is it too hard to read it yourself? sorry for being an *** but it was just too easy of an opportunity.
if you can't find the ecu codes then go here.http://users.adelphia.net/~rescue70/ecu.html
vis213
i never saw a topic specifically saying the process for the CA...it was all KA
float_6969
It's in the FAQ. Please read through the whole thing carefully. I just double checked and it's there, sure enough....
