davidricardo86 »
https://forums.nicoclub.com/davidricardo86-u32537.html
Tue Jun 02, 2009 6:18 am
From it's original position, turn the diagnostic screw on the ecu to the right. This will put you into mode selection which sounds like what you're describing. If I remember correctly mode three or three blinks is the mode that will tell you which trouble codes if any are stored in memory. Immediately after the three blinks turn the diagnostic screw back to the left, or it's original position. The ecu will then perform a sequence of blinks. Five blinks followed by five more blinks is code fifty five. Code fifty five means that there are no codes in memory.
Just because you don't get any codes doesn't mean that a problem won't exist though. Some other electrical or mechanical issues might be at large.
Download the fsm if you haven't already. Everything you need to know is readily available.
